Use the following procedure to view the IKE version 2 security association.
  1. In the navigation pane, expand Configuration > Security > Control Path.
  2. Select IKE.
  3. Select the V2 SA tab.
V2 SA Field Descriptions
Use the data in the following table to use the V2 SA tab.
Name
Description
Id
Specifies the profile ID.
LocalIfIndex
Specifies the Interface Index of the local address. Only port and vlan interfaces are supported.
LocalAddrType
Specifies whether the local address is an IPv4 or IPv6 address.
LocalAddr
Specifies the address of the local peer.
RemoteAddrType
Specifies whether the remote address is an IPv4 or IPv6 address.
RemoteAddr
Specifies the address of the remote peer.
Name
Specifies the name given to the SA.
AuthenticationMethod
Specifies the proposed authentication method for theVersion 2 security association.
The default authentication method is pre-shared key.
DPDTimeout
Specifies the Dead Peer Detection timeout in seconds.
HashAlgorithm
Specifies the hash algorithm negotiated for this IKE Version 2 SA.
EncryptionAlgorithm
Specifies the encryption algorithm negotiated for this IKE Version 2 SA.
EncryptKeyLen
Specifies the encryption key length negotiated for this IKE Version 2 SA.
DHGroup
Specifies the Diffie-Hellman group negotiated for this IKE Version 2 SA.
ExchangeMode
Specifies the IKE Version 2 SA mode.
LifetimeSeconds
Specifies the amount of time for which an IKE Version 2 SA can remain valid during IKE Version 2 negotiation. A value of 0 means no the SA always remains valid.
Status
Specifies whether the SA is active or inactive.
Initiator
Specifies whether specifies the whether the SA is created by an initiator or a responder.
IntegrityAlgorithm
Specifies the type of integrity algorithm.
